06-09-2013 #4
As you probably guessed, the reason I spoke in the youtube video you linked to was so that you could set the volume so that I'm speaking at a normal volume, and judge the noise from the spindle accordingly.
I doubt the spindle from amazon will be quiet as it has a fan on the end, so there will be noise created by the airflow. This is unnecessary when you can quietly water cool it. Don't be afraid of the water cooling - it can be simple and easy.
If you go for one of the better quality (and much more expensive) water cooled spindles, I'm pretty confident you'll find it's a lot quieter than the standard 2.2kW ones. The one I used here is that type, and I recently obtained a 3kW one on eBay for the right price which is even quieter:
Admittely it's a bit on the large size for your machine, but I expect the 0.8kW one isn't going to be worse. Also you'll get much lower runout (a few micrometers) with these spindles, which could be an advantage if you're cutting a particularly detailed PCB. I can post a video with them both switched on one at a time if you want to compare?
Edit: Unfortunately I don't have a new enough phone to measure sound level.
P.S. Where about is 'on the move'? Clearly the best way is for you to actually listen to one - you're welcome to pop round...Last edited by Jonathan; 06-09-2013 at 07:42 PM.
The Following User Says Thank You to Jonathan For This Useful Post:
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Workshop & Noise Help
By kemo_2002 in forum Workshop & EquipmentReplies: 7Last Post: 12-04-2014, 10:16 PM -
controlling a stepper with a simple trigger switch
By phill05 in forum Stepper & Servo MotorsReplies: 13Last Post: 06-02-2014, 02:18 PM -
Motor noise
By M250cnc in forum General ElectronicsReplies: 4Last Post: 25-11-2010, 02:06 PM -
PDA Controlling A Steeper Motor
By ceaser in forum Stepper & Servo MotorsReplies: 5Last Post: 23-05-2009, 03:03 PM
