Pointless seeking advice if I don't act upon it, so upon your recommendation, I've just this minute pulled the trigger on this VFD...
toshiba vfnc3s-2004pl inverter | eBay (which is what the model that you linked to)
Toshiba are normally a good make, so I'll take a leap of faith here!
I think just to get up and running, I'll go with a passive option (pump & a bucket - I'll get slick later)....has anyone a recommendation for a quiet suitable water pumpLast edited by HankMcSpank; 06-09-2013 at 10:16 PM.
06-09-2013 #2
Hey, wise choice. Hitachi also are good but in EU Toshiba is best priced.
NOTE: VFNC3S-2004PL. Toshiba Tosvert VF-nC3 Inverter for 0.37kW (0.5HP) 230V
The one i recommended you was the 2007PL for the 0.8kw
Did you make a mistake or bought this on purpose for your smaller motor?
06-09-2013 #3
oops....that what I call a F*&% up!
I searched Ebay UK for the model in the italy ebay ad you linked to ...and Ebay returned the one I've just bought...I overlooked that model number difference! (heaven knows why it was returned in my search)
I've emailed the seller, hopefully we can cancel the transaction!!Last edited by HankMcSpank; 06-09-2013 at 10:48 PM.
06-09-2013 #4
If your concerned about getting the Chinese VFD, which I wouldn't be, bear in mind if you get the 1.5kW or 2.2kW version and run a spindle rate for only 800W then it's always going to be operating at a tiny fraction of the rating. This means it's not going to get hot, and heat tends to be what wears out electrical components. Also, plenty of people here use them so it's guaranteed to be easy to set up.
The Following User Says Thank You to Jonathan For This Useful Post:
06-09-2013 #5
I agree but there are 3 main points where i am not happy with Chinese VFD:
1. The documentation
The Toshiba VFD has 300 pages manual and every detail is explained in even greater detail. Its quite exhausting to program the VFD for one that has no idea on what it does exactly. I remember spending a week programming my first VFD. Now imagine the ammount of forums that have to be read to learn the same for the Chinese VFD
2. Warranty
Warranty in EU, not China
3. Price
For a 120eur for the 800w ones for me its a no brainer. However the Chinese one could be interesting in the 2.2-3kw range
Anyways, depends from the point of view. Every machine has critical parts and for me the VFD is one of the most critical. For example i use many of the functions of the said VFD. Like detecting stall and similar and tripping above a pre programmed amperage draw. The enable on my BOB is driven by the VFD. I leave the machine sometimes do long jobs. The machine is powered by 1500w UPS power supply. So if the electricity stops, if the VFD is not connected to the BOB, the machine continues doing whatever it does for half an hour more but the spindle does not rotate, imagine the mess and damage. Sometimes a bit breaks or digs and instead of damage, the VFD trips. i dont know of the functions of the Chinese VFD which possibly are the same. Just like playing safe, at least for a 800w spindle. For my next machine i could also contemplate 3kw chinese kit due to price.
06-09-2013 #6
07-09-2013 #7
Ok, the seller graciously let me off the hook :-) (lesson learnt - never buy when you're tired & don't trust the Ebay search....get into the detail!)
So ok, since I've now I've been won over into getting a VFD for me 800W water cooled spindle ....the Toshiba in Italy is 0.75KW OUTPUT ...& whilst i'll never upgrade the spindle that I have to a larger one, i do agree with jonathan that it's best to over spec (therefore buy a 1.5kw vfd) because the components will be rated higher & won't break out into a sweat. This leads me back to Chinese ....but there seems to be a huge number out there.
Is there any one particular model that I should seek out? (or avoid?!)
Some VFDs seem to be sent from Portsmouth...which appeals as I'd rather not wait 4 weeks to get up & running on my new machine purchase.
07-09-2013 #8
When I was working in industry ABB was always my first choice for drives, I have one on my overhead pin router. I've never used the Chinese ones but there is usually a parameter for switching frequency, not the same thing as output frequency, this can reduce the noise coming from a motor.
http://www.danfoss.com/NR/rdonlyres/...eReduction.pdf
The Following User Says Thank You to EddyCurrent For This Useful Post:
07-09-2013 #9
Manufacturers state that its Not OK to oversize or under size VFD . The maximum acceptable is 1 size bigger. I believe its because of trip sensitivity. Obviously 4.5 A rated VFD like the 800W can drive 1500w motor. As 800w spindle consumes 2-2.5A in reality and 1500w motor consumes 4A.
So in fact there is no need at all to oversize VFD as they are strong enough for 10 years non stop use as i remember from the specs. You should check though the manual if you decide to oversize. Need to check if you can program all the parameters of your current motor, like current draw, size, etc. cause what is the point of getting bigger if it could not drive properly the motor you have. Cause i believe certain manufacturers will not permit programming of smaller motor.
Also to avoid further mistakes, find the specs of your motor. Check at what voltage and what frequency is driven! The VFD i recommended you drives 3 phase motors up to 400HZ at 230v. Check if your motor is 200, 300, 400hz or even more and if 230 or more volts. This is very important so you can couple it correctly with the VFD.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
07-09-2013 #10
Thanks for your input (it really is appreciated), re the spindle, I will try & establish more info about it, but the seller said that this was the original VFD that came with it....
VFD Inverter 2HP 1.5KW 4 Spindle Motor 1/3Ph In-3P Out | eBayLast edited by HankMcSpank; 07-09-2013 at 11:40 AM.
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Workshop & Noise Help
By kemo_2002 in forum Workshop & EquipmentReplies: 7Last Post: 12-04-2014, 10:16 PM -
controlling a stepper with a simple trigger switch
By phill05 in forum Stepper & Servo MotorsReplies: 13Last Post: 06-02-2014, 02:18 PM -
Motor noise
By M250cnc in forum General ElectronicsReplies: 4Last Post: 25-11-2010, 02:06 PM -
PDA Controlling A Steeper Motor
By ceaser in forum Stepper & Servo MotorsReplies: 5Last Post: 23-05-2009, 03:03 PM
