12-10-2013 #33
Possibly as suggested by Jonathan, wrong programming of the VFD. Its a very long manual, i know. But is unavoidable. Follow it step by step.
Check the phases on the motor! Wait for the VFD untill the led goes out after disconnecting before you touch anything!
The spindle can work hours without water without heating.
You don't need a pot right now. The button on the VFD rotates and you change the frequency.
Read the manual. the VFD stores last trips, you can go there and check what happened exactly, so no need to measure anything. During operation you can also monitor A, V and so on calling them on the display with a button.
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Workshop & Noise Help
By kemo_2002 in forum Workshop & EquipmentReplies: 7Last Post: 12-04-2014, 10:16 PM -
controlling a stepper with a simple trigger switch
By phill05 in forum Stepper & Servo MotorsReplies: 13Last Post: 06-02-2014, 02:18 PM -
Motor noise
By M250cnc in forum General ElectronicsReplies: 4Last Post: 25-11-2010, 02:06 PM -
PDA Controlling A Steeper Motor
By ceaser in forum Stepper & Servo MotorsReplies: 5Last Post: 23-05-2009, 03:03 PM
