12-10-2013 #28
Just the base frequency setting isn't what you need, as that's the voltage at the rated frequency (400Hz), but we need to know the voltage across the whole range. Have you checked that the frequency this voltage refers to is definately 400Hz, as if it's 50Hz that would explain what's causing the problem, as it means the VFD is applying 8 times the required voltage at 50Hz.
You're correct in saying that a DC output of 230V would imply a very high current (although it's not 230V DC, 84V or even 28A), but fortunately the VFD outputs AC not DC! The impedance of the spindle increases with the frequency applied. You can think of impedance as resistance, but for an AC circuit with inductors/capacitors. So at 0Hz (DC) the impedance is equal to the DC resistance you measured (3 ohms, which sounds about right), but as soon as you increase the frequency the impedance increases proportionately. It also changes with load. That's why as the frequency increases you need to apply a higher voltage to be able to output the same torque. So in short your measurement implies that the winding's aren't burn out, but it's nowhere near enough to say if the spindle will work.
Strangely the translated chinese manual for the VFDs most people get to control their spindles are easy to understand.
Have you got skype? If you're sitting there with the VFD we can probably sort this out in half an hour...
The Following User Says Thank You to Jonathan For This Useful Post:
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Workshop & Noise Help
By kemo_2002 in forum Workshop & EquipmentReplies: 7Last Post: 12-04-2014, 10:16 PM -
controlling a stepper with a simple trigger switch
By phill05 in forum Stepper & Servo MotorsReplies: 13Last Post: 06-02-2014, 02:18 PM -
Motor noise
By M250cnc in forum General ElectronicsReplies: 4Last Post: 25-11-2010, 02:06 PM -
PDA Controlling A Steeper Motor
By ceaser in forum Stepper & Servo MotorsReplies: 5Last Post: 23-05-2009, 03:03 PM
