  1. Quote Originally Posted by phill05 View Post
    What if you had a steel rod of say 19mm dia as the sliding part down the bore?
    That might work. A quick mental calc says about 4mm deflection at 1m with 600mm of rod in a 600mm tube (ie min height would be 600mm). I need to do more accurate bending calcs and torsional calcs as may allow too much rotation Weight is about 2.9kg. Only downside is a 1" pole looks aesthetically 'flimsy' lol
  1. Telescopic Gauges
    By birchy in forum Marketplace Discussion
    Last Post: 28-06-2013, 01:02 AM
  2. Using SBR12 as ballscrew end support
    By Lovre in forum Lead Screws, Nuts & Supports
    Last Post: 13-12-2012, 08:52 PM
  3. RFQ: I need Help/Support with my project :)
    By gianluca_g in forum Projects, Jobs & Requests
    Last Post: 06-05-2012, 10:00 PM
  4. Looking for Vacuum/Swarf extraction tubing
    By m.marino in forum Machine Discussion
    Last Post: 18-08-2009, 12:35 AM
