  1. the problem with matting is its discontinuous, i have some pictures somewhere i will try to dig them outall the rails were mogliced into position from masters
  2. The Following User Says Thank You to compositepro For This Useful Post:
  3. #32
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 19 Hours Ago Has a total post count of 804. Received thanks 101 times, giving thanks to others 176 times.
    That would be much appreciated, if/when i do find the time to build a machine i would like to make the gantry from composite.
    Regards
    Mike
  4. #33
    I've got to grips with the spreadsheet now and I'm tending to return to the L gantry but I'm trying various combinations of sizes to find the optimum strength/weigh/cost ratio although cost is secondary but still important.
  5. #34
    After that trip into outer space I'm back on earth and it looks like the L gantry is going to be the way forward. You would think I was building an electron microscope, it's only going to have a bed 900x600 but I realise it has to be stiff. Currently drawing up the whole machine for comments but getting the Z axis right might take a day or 2 as I want to keep overhang to a minimum.
  6. #35
    Wise Choice, really couldn't under stand the need to re-invent the wheel.? . . . KIS approach is all that's needed for wood router. Better investing your efforts into quality components than wasting time and money trying new approach when proven designs work fine.
  1. Cast aluminium gantry router
    By jrcast in forum Gantry/Router Machines & Building
    Last Post: 17-02-2017, 08:13 PM
  2. RFQ: RQF: Router Gantry plates
    By lateAtNight in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 04:56 AM
  3. Double gantry idea, What do you guys think?
    By craigrobbo in forum Gantry/Router Machines & Building
    Last Post: 25-12-2012, 10:01 PM
  4. Router spindle idea
    By HiltonSteve in forum Spindles & Drive Motors
    Last Post: 19-01-2010, 08:59 AM
  5. BUILD LOG: Fixed Gantry Router
    By lateAtNight in forum DIY Router Build Logs
    Last Post: 28-05-2009, 11:30 PM
