06-09-2013 #1
I have blender. never used it. I have the script than is supposed to go in the "python console". tried it dozens of times, cant get it to work and I don't know what I am doing At All in that software.
There must be an easier way to convert this. Maybe not free.
Anyone know of maybe a 15 day evaluation software that allows the export of the mesh file please ??Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
07-09-2013 #2
Have you tried using Rhinoceros?
I know JazzCNC (Dean) uses it, and I am sure he will post in due time."If first you don't succeed, redefine success"
The Following User Says Thank You to Mad Professor For This Useful Post:
07-09-2013 #3
The Following User Says Thank You to EddyCurrent For This Useful Post:
07-09-2013 #4
Yes rhinoceros will do this and they used to give free unlimited functions demo limited to 28 saves no time restriction.
07-09-2013 #5
I have searched google but have not come up with a solution for this small issue.
I ran the digitizing wizard in Mach3 twice. The txt file is completely empty after both attempts. The properties show 0 bytes on the file.Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
Mach3 digitizing wizard not saving file
By dudz in forum Probing, Digitizing & ScaningReplies: 0Last Post: 08-09-2013, 09:48 PM -
Digitizing probes practicality
By dudz in forum Probing, Digitizing & ScaningReplies: 2Last Post: 04-06-2013, 03:31 PM -
Mesh cam or other?
By totts in forum CAD & CAM SoftwareReplies: 0Last Post: 26-08-2011, 04:57 PM -
Probing / Digitizing - What the best way to do this job?
By Mad Professor in forum Probing, Digitizing & ScaningReplies: 2Last Post: 08-05-2011, 12:32 PM -
Digitizing
By Mad Professor in forum Probing, Digitizing & ScaningReplies: 2Last Post: 06-01-2011, 06:52 PM
