  1. #7
    Thanks guys,
    so it seems clear to me that i will pull the trigger at the straight edge. A sort of investment.
    The 2 angle finders from aliexpress will wait for the moment. My idea was to use them like this:
    Look at the gantry picture bellow. Using the straight edge or epoxy , like for the long rails, i could flatten the upper side/1/
    But then how to flatten the opposite side? I don't have a fixed gravity epoxy formed horizontal surface at home. If it was my proper house, i would have done it long ago. So just flipping sides and pouring epoxy would be simple. So i thought of connecting the 2 angle finders un U like shape so i can measure distance and parallelism bots sides. So using the epoxy leveled top or bottom as a reference i could file , sand and so on, the other side. if they were on one plane , it would be easier, but damned overhang...i don't like it.
    Anyways, i bought 2 packs of 1kg west system epoxy kit 105/209. After pouring some where necessary, the rest i will use to form a flat table surface and fix some short adjusting legs. As i have a very precise inclinometer / ~0.5mm per 3m, or so i calculated it when i bought it, don't remember but was the most precise on ebay/ i can fix me a portable level base precision surface for similar projects. I need a bigger garage:-)
    Another thing is that just now i found how to make precision straight edge at home. 3 edges in fact. very interesting read. Now i am contemplating how to make it in reality. will need some polishing paste. maybe vibrate the edge for quicker removal. or slowly, like making a katana, while watching movies at night at home...
    PS. i want to be as most as precise as possible, cause i know that even if you try, you are not. So if you don't try, its even worse
  1. understanding stepper motor ratings.
    By jcb121 in forum General Electronics
    Last Post: 30-09-2013, 04:06 PM
  2. late spring cleaning measuring tools
    By dsc in forum Tool & Tooling Technology
    Last Post: 11-07-2013, 11:04 AM
  3. can't cut straight or even drill straight, so need help
    By deannos in forum Machine Discussion
    Last Post: 02-10-2011, 05:35 PM
  4. Understanding the bearing block
    By Rogue in forum Rails, Guideways & Bearings
    Last Post: 28-08-2011, 03:14 PM
  5. Help understanding the software side of cnc routing.
    By don_jarr in forum CAD & CAM Software
    Last Post: 23-06-2011, 01:13 PM
