Thread: VFD retrofit Hobbymat BFE65
10-09-2013 #3
I assume you meant AC control? If so, the mechanics are probably the hardest thing to do...in particular getting a motor small enough to fit the machine without giving up too many horses.
Regarding motors, the basics are that a 4-pole will run at approx 1425RPM at 50hz and a 2-pole will run at around 2850RPM at the same frequency. The big decision is whether to choose the slower 4-pole (for more torque at low speeds) or the higher top speed of the 2-pole but with reduced torque at low speeds. You can use stepped pulleys or gears to overcome this but I just didn't have the room for such niceties on my machine.
The Following User Says Thank You to birchy For This Useful Post:
Hobbymat BFE65 Leadscrew info, fitting anti backlash nuts
By manofgresley in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 09-05-2014, 04:35 PM -
SWAP: Hobbymat Lathe For CNC
By palmerlad in forum Items For SwapReplies: 2Last Post: 12-11-2013, 06:33 PM -
FOR SALE: Hobbymat MD65 Metal lathe
By craigrobbo in forum Items For SaleReplies: 1Last Post: 13-09-2013, 05:04 PM -
Hobbymat MD65
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 29-08-2012, 09:36 PM -
Hobbymat BFE65 Conversion - Gearing my Steppers?
By jamezwarner in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 06-09-2011, 06:08 PM
