Thread: Z Axis appraisal please
13-09-2013 #11
Why don't you use steel profile gantry? Or at least steel profile and aluminum profile mix if you insist on using aluminum profile? Profile is much stronger than plate. It would be good idea to check your design with the calculator posted in the sticky area of the forum. Personaly i dislike plate sides of gantry if they are not double, imitating profile.
13-09-2013 #12
I mentioned this in my post because I knew it was crap but I'm changing it now.
I agree but I like the look of this design better anywayThink about the machine your building not what some spread sheet that somebody who's never probably built a CNC machine predicts is the optimum location, Or from looking at some poorly built machine who's getting less than expected results then blaming there crappy build quality on design style.
Same as point 1Your insistence on keeping Z axis slim and low is seriously compromising the machine.!! . . . Front or rear screw no matter but this Z axis is wrong.
Lift the bearings and rear plate so they are supported by the gantry other wise the back plate will flex under cutting forces.!
What happened was I was concentrating on the top bit and forgot about the overhang until I posted the pics and saw it.
Also moving it to a Build Log next.
Thanks for comments.Last edited by EddyCurrent; 13-09-2013 at 10:25 PM.
13-09-2013 #13
I was thinking I might add a 12mm plate to the flat back side of the gantry to tie it all together. I know some designs have double gantry sides but I'm conscious of the gantry weight and also feel the depth of the gantry cross members will prevent any flexing of the sides. But I may be wrong !
Thanks for your comments
13-09-2013 #14
13-09-2013 #15
Continues here
http://www.mycncuk.com/forums/router...eady-eddy.html
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Y axis is making X axis stall...!!
By fasteddy in forum Machine DiscussionReplies: 83Last Post: 24-10-2011, 12:19 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
