Thread: Aluminium adhesive
Thanks for the input guys. I will go with the bolt & adhesive option then. Will go for a loctite structural epoxy, grade tbc.
I'm guessing the entire surface won't have to be coated only dabs equally spaced across the area?
With the fixings to bolt the ballscrew bearings on etc do people tend to loctite these in due to vibration or use spring washers or nothing at allDan
13-09-2013 #2
18-09-2013 #3
I do a lot of bonding things together ,think things that pull lots of G's
Bonding would be a great way to go with some rivets in there also
Remember aluminium is filthy to glue together ,the same oxide layer that likes to form to stop it corroding regardless you need to etch it and prep and for high end applications actually convert the surface to a different layer substrate, clean it and degrease it scrupulously if you do not have access to acid etch or anodic treatments ,the strongest adhesive is useless if it cannot get purchase on the alloy
Dabs of glue? bonding rlys on film thickness ,called a bondline dabbing blobs will cause unevenness you need a uniform bed of adhesive ,dont think of it as liquid nails unless your doing your skirting boards
Also aluminium rivets act as mechanical fuses should your glue decide to divorce itself from the aluminium will not allow you to apply forces that will distort the jointLast edited by compositepro; 18-09-2013 at 07:15 PM.
The Following User Says Thank You to compositepro For This Useful Post:
09-11-2015 #4
Although the thread is really old, maybe someone is still interested in these theme.
I used a heatadhesive for aluminium from the german company delo.
the only disadvantage of the ad. is, you must heat the parts for at least 1/4hr to iirc 150°C.
After that, you can never open the connection.
Aluminium box section
By martin54 in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 28-10-2012, 01:13 AM -
BUILD LOG: Aluminium CNC log.
By jcb121 in forum DIY Router Build LogsReplies: 111Last Post: 04-04-2012, 01:37 AM -
First Aluminium cut
By luke11cnc in forum Computer SoftwareReplies: 15Last Post: 24-02-2012, 09:39 AM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
