  1. I do a lot of bonding things together ,think things that pull lots of G's
    Bonding would be a great way to go with some rivets in there also
    Remember aluminium is filthy to glue together ,the same oxide layer that likes to form to stop it corroding regardless you need to etch it and prep and for high end applications actually convert the surface to a different layer substrate, clean it and degrease it scrupulously if you do not have access to acid etch or anodic treatments ,the strongest adhesive is useless if it cannot get purchase on the alloy
    Dabs of glue? bonding rlys on film thickness ,called a bondline dabbing blobs will cause unevenness you need a uniform bed of adhesive ,dont think of it as liquid nails unless your doing your skirting boards
    Also aluminium rivets act as mechanical fuses should your glue decide to divorce itself from the aluminium will not allow you to apply forces that will distort the joint
  2. The Following User Says Thank You to compositepro For This Useful Post:
  1. Aluminium box section
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 28-10-2012, 01:13 AM
  2. BUILD LOG: Aluminium CNC log.
    By jcb121 in forum DIY Router Build Logs
    Last Post: 04-04-2012, 01:37 AM
  3. First Aluminium cut
    By luke11cnc in forum Computer Software
    Last Post: 24-02-2012, 09:39 AM
  4. Aluminium passivation - for aluminium to be used outside
    By CHudson in forum Metal Finishing Techniques
    Last Post: 06-04-2011, 09:18 PM
  5. MDF or Aluminium
    By rob_colby in forum Gantry/Router Machines & Building
    Last Post: 24-10-2010, 09:36 PM
