  1. Both are easy to machine on a manual lathe
    Carbide and a good depth of cut will do it nicely tiny cuts are not your friend with either material En24T and 12.9 drills beautifully
    If you are doing it with cobalt m42 bits put a 0.4 radius on the tool and select a feed per ref roughly half the radius but keep your tool sharp
    the problem is you are doing 40 which is CNC qty money
  1. Replies: 50
    Last Post: 01-07-2022, 04:11 PM
  2. RFQ: Dublin, IRL Manual milling & lathe work required
    By 250rri in forum Projects, Jobs & Requests
    Last Post: 30-01-2014, 01:07 PM
  3. Manual Tapping Machine
    By newtoid1986 in forum Marketplace Discussion
    Last Post: 27-04-2012, 05:23 PM
  4. Cheap Lathe CAM or manual g-code?
    By m_c in forum CAD & CAM Software
    Last Post: 17-10-2011, 04:27 PM
  5. RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
    By Chas in forum Projects, Jobs & Requests
    Last Post: 07-11-2010, 09:28 AM
