    I had to strip it down a bit today because there was still a BK and FK bearing to sort out, both had bearings in facing the same way and no grease, made shims, greased, reassembled.
    More progress, ready to order some energy chain and start wiring and I'm very pleased the panel is already built.
    Limit and home switch for Z axis, there is one switch and two strikers. For the home switches I mounted a piece of 6mm thick mild steel to aluminium angle to act as the target.
    Motor mount for Y axis
    limit switch and adjustable striker for Y axis, there's another striker at the other end of the gantry, so one switch with two strikers.
  2. The Following 2 Users Say Thank You to EddyCurrent For This Useful Post:
  1. traveling steady, turning 1/2 bar down over 10".
    By graffian in forum Metalwork Discussion
    Last Post: 08-05-2013, 07:59 PM
  2. NEW MEMBER: Hello all, finally ready to start a build log.
