Thread: Ready Steady Eddy
Geoffrey, I was going to make it like that, but during some earlier trials, I found on some 3D stuff that if it didn't follow the tool down, then gaps around the bottom would appear in some areas.
Getting tension right might work but I can't see how it could be controlled very well. I was thinking that by some mechanical arrangement, the dust shoe could be made to advance at a slower speed that the tool, say 60%, I'll have to think about that.
Edit: now I've had some mackerel for breakfast thinking has improved. Looking at the pictures in my earlier post, the dust shoe is supported by two rods held in blocks with wing nuts. If those blocks were replaced by a tube with a spring inside this might apply the right pressure. As the tool advances so would the pressure on the springs and the shoe would lower slightly. Adjusters could be made to alter spring tension.Last edited by EddyCurrent; 12-11-2014 at 11:03 AM.
12-11-2014 #2
Eddy spoke to my friend last night about this and it was exactly this reason why it didn't work well for him. It worked fine for panel work and engraving etc but was rubbish for Deep 3D work and he mainly makes casting moulds on his machine so no good.
He's played with various setups and found that the only way to deal with 3D with any decent success is to have a larger vaccum area and with big bore vacuum. The little vacs couldn't get enough volume over the larger area.!! . . . Basicly you need excess vacuum to blitz the area.
He said Small shop vac was fine for everything but deep 3D work.Last edited by JAZZCNC; 12-11-2014 at 10:51 AM.
12-11-2014 #3
12-11-2014 #4
6" is much better than 4" ... http://billpentz.com/woodworking/cyc...g_introduction
12-11-2014 #5
12-11-2014 #6
The creative adult, is the child who survived
12-11-2014 #7
@ba99297, wrong thread my friend, I've done it myself so no worries.
18-11-2014 #8
Since using the latest Smooth Stepper plugin for several weeks, months ? I've had no problems with homing the X and slaved A drives, I would say that issue is now sorted.
ESS_v10r2d1d.zipSpelling mistakes are not intentional, I only seem to see them some time after I've posted
19-11-2014 #9
And it only took them ~5 years to get it right.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
19-11-2014 #10
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
