Thread: Ready Steady Eddy
28-01-2014 #111
It does say low viscosity, but as you say is it really worth it? Does look like it'll fit the bill mind! I'm just drawing fences on my frame to see what volume I'll need...I've emailed them to see if it's equivalent to the Wests System!
28-01-2014 #112
Oh feck it....rush of blood to the head.....should have some winging it's way to me shortly. £33.36 inc P&P for 1.5kg of resin and 0.5kg of slow cure hardner. Will have a play and let you know how it pours. I reckon that I'll need 0.63 litres of mixed epoxy for 5mm depth so the standard pack should do nicely!
28-01-2014 #113
Now I feel responsible if it's shit so I'll have to order some as well
I was going to anyway, I like to live on the edge sometimes
Anyway just compared viscosity, West = 650 cps, Syntac 650-750 mPas, (1 cps = 1 mPas)
I'm thinking the main thing here with both of them is to get a good temperature going before pouring, it needs to be string vest only temperature minimum in the shed.
http://www.westsystem.com/ss/assets/...%20105_209.pdf
http://www.reactiveresins.com/syntac...poxyresins.pdfLast edited by EddyCurrent; 28-01-2014 at 04:40 PM.
28-01-2014 #114
Don't worry about it Eddy...I compared and they looked pretty identical...so in a rush of blood to the head bought some. You'll probably be using it before I do anyway as I've got 44 x M5 holes to drill and tap for the rails and before I can do that I've got to make a plate so I can get the linear carriages mounted to get the rails in the correct position on the box section. At the rate I'm going at the moment it will be summer by the time I've done that
28-01-2014 #115
It's interesting you say you'll make it hot in the shed as I was just wondering whether it would be better to make the environment warmer or cooler. The mixture will certainly start of with a lower viscosity if it's warmer but it will also set faster as well (a rule of thumb from chemistry is a reaction will go twice as fast for every 10 deg C warmer) which means there is less time for it to find a level everywhere. I can't help feeling you'd be better off working with it as cold as you can to give it time to spread out before it sets. It says it'll cure down to 8 deg C if you are willing to accept a reduction in mechanical strength. Might be worth an experiment, make up a small amount cold and pour it onto a piece of scrap, see how far it spreads then repeat with a warm batch / environment.
28-01-2014 #116
See the Chemistry did come in useful!!
My shed will be ideal then as it's bl***y freezing in there at the moment!!!I can't help feeling you'd be better off working with it as cold as you can to give it time to spread out before it sets. It says it'll cure down to 8 deg C if you are willing to accept a reduction in mechanical strength.
I'll do mine in the test bay at work, there's one bay used for storage that's colder than the rest but still above 10°C I'd guess.
I'll be doing that for sure before committing to the real thing. I wonder if you can gradually increase the ambient temperature once it's had 12 hours or so to find the level so that you get the best of both worlds?!Might be worth an experiment, make up a small amount cold and pour it onto a piece of scrap, see how far it spreads then repeat with a warm batch / environment.
28-01-2014 #117
It's just that the West data sheet says this;
Minimum recommended temperature 70°F (21°C)
*Epoxy cures faster at higher temperatures and in thicker applications
and the Syntac data sheet quotes the viscosity at 25 deg.CLast edited by EddyCurrent; 28-01-2014 at 05:49 PM.
28-01-2014 #118
I think you should be careful re the temperature read the link to the wests system and it shows that it must not be cold, also I would check with your supply what the shrinkage and compression strength is of their product as there is not a lot of info on their data sheet. Don't forget to seal the inside of the trough because if you have any leaks it won't leave a level surface. Good luck. ..Clive
28-01-2014 #119
Well I'll be having the wood burner going anyway, it says the pot life is about 40 minutes so surely that's enough for it to settle ?
For making the trough I was thinking about using this, do you think the epoxy will eat into it ?
10x10mm, 1.75M, Foam Sealing Tape Adhesive Strip, Draught Excluder, EPDM Rubber | eBay
Edit: this is better, I'd missed the fact that previous stuff was only 1.75m long.
http://www.toolstation.com/shop/Iron.../sd2802/p70101Last edited by EddyCurrent; 28-01-2014 at 11:01 PM.
28-01-2014 #120
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
