Thread: Ready Steady Eddy
	04-04-2014 #271
Great stuff Eddy, well done, now youcan start to think about cutting something intricate!!! G.
	04-04-2014 #272
Thanks, for a start I'll need to get some small ball nose cutters, it's something I've never needed to use in the past.
	04-04-2014 #273
Looking wonderful and very professional. Very well done. One question though (ducking behind the wall) where's the lube blocks???
Just being cheeky as you have done a very very good job and I am in the process of getting my control box anywhere near the well laid out set up you have done. -MichaelSoftware SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
	04-04-2014 #274
Eddy i am not professional but i want to say that your job looks grate. I don’t know if there are mistakes but for sure there is much good mood. One more time congratulations for your job. I manage that soon i will start mine cnc router.....
	04-04-2014 #275
	04-04-2014 #276
Vagelis, thank you for your thoughts it's much appreciated, I will keep watching your build log.
I still have the bed to finish but I've ordered a sheet of 18mm birch plywood today and I will be bolting one half to the steel frame, give it a skim with the router to get it flat, then screw the other half on top and give it a final small skim. As I intend cutting wood that will be fine but if aluminium needs cut I'll have to mount it in a shallow pan to catch the cutting fluid.Last edited by EddyCurrent; 04-04-2014 at 04:30 PM.
	04-04-2014 #277
Eddy,
Lube points for bearing surfaces. When they are brought to a common point for charging it is called a lube block as it is either a single pump point with a multiport outlet or it is a bunch of singles that are bolted together to make a block that is mounted to the machine. I hope that makes sense used to install them all the time on machines to be able to lube a area within the machine without having to tear part of it apart. -MichaelSoftware SolidWorks 2024, Onshape, Aspire v9.5, Blender
	04-04-2014 #278
Ah I see now, I'm using grease not oil so it's a manual operation with a grease gun. I think I would refer to the 'lube block' as a 'manifold'
	04-04-2014 #279
Correct same thing. Though they can be used for both grease or oil depending on how they are set up. Most of the ones we did where grease under low pressure so that the line would do a slow feed which helped keep clean grease where you needed it. -Michael
	04-04-2014 #280
Thanks for the info Ed. Sounds like you tested your E-stop circuit a few times during the process!
I think i'll definately try that combo on my setup first. Hopefully it will work even though i'm using 2 homing switches on the X-axis. I'll let you know how I get on.
Si.
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
