    Hi Eddy,
    for sure you know from the other threads already my preference is not for that type of design, i like 80x80 and 100x100 x 3mm, but your design looks ok for the job intended.
    However just some points from design and strength point of view. Forget about the 1m more or less for a moment, as this profile is not so costly or heavy.
    The main principles should be: simple, all parts under equal load , no parts that transmit the flex from above to the same place bellow, divide and conquer/strengthen :-) / and no parts that serve only one purpose, so:
    -look at drawing 1 and 2 . The bar at the lower part that is in the middle of the rectangular. I don't like it. If there were 2 of them , they would keep the table from twist. Now that is only one in the middle, it just holds both long sides at same distance. Not only that but transmits the flex from above in the same place bellow. And separates only in 2 the long sides.
    i would put 2 of them or none, instead solder 4 diagonals in such a way that the long and the short sides are separated each in 3 equal pieces, or somewhere near it
    -diagonals on the sides on 1, separate the upper rail support only in 2 pieces, and on drawing 2, they separate the upper rail support onto 3 pieces but not equal and also are soldered very high on the legs.
    that leads me to the next
    -the middle side support in drawing 2 does exactly what should not be done, transmit the flex from the middle on the exactly same place bellow.
    Solutions? Think in arcs. Like the door of a stone house or castle or so. 1 short horizontal bar each from one side, soldered 15cm below the rail supports directly to the previously suggested diagonals position will strengthen the arc, permit the diagonals to go lower at their low ends, and that combined with the removal of the middle vertical bar and replacing the bottom middle bar with diagonals will make everything stronger, resistant to twist and most importantly remove any push from the lower rectangular replacing it with pull, which in fact is way stronger. Or no horizontal bars , the rails supports are double and look quite strong in vertical direction...You can pull a lot but push very little :-)
    Just an idea how my thoughts go, there are other ways to do it also. It would work like this and like that, though there is quite a satisfaction achieving some perfect shape!
    PS. Lowering the diagonals on the sides will achieve the following. Now if pressure is applied from above in the middle, the diagonals push the legs in the middle and try to bend them. If slightly lowered their end, they will start pulling the lower part long sides and remove the push from the legs.
  1. traveling steady, turning 1/2 bar down over 10".
    By graffian in forum Metalwork Discussion
    Last Post: 08-05-2013, 07:59 PM
  2. NEW MEMBER: Hello all, finally ready to start a build log.
