Thread: Ready Steady Eddy
13-11-2013 #10
Visio but any 2D CAD will do, it's just that I had already created the symbols with it. By the way a good source for electrical symbols is the Telemecanique catalogue, you have to draw them youself and save as a block but it's still a great resource.
No not particularly but I have included some spare terminals if need be with the idea of adding another breakout board, the Smooth Stepper has connectors for 3 ports. The enclosure is pretty full now and I like everything to fit onto the backplate, other than door mounted buttons etc.
The spindle is an ELTE 2.2kw TMPE3 12/2 and has a built in switch for temperature.
In my panel all the low level signal wires go in the right hand vertical trunking while the stepper motor and power wiring are in the left hand vertical trunking. The stepper motor wiring and spindle motor wiring are in screened CY cable, all screens earthed at the terminal rail and nowhere else.
If anyone is concerned, it might be worth their while to look up IP2X for electrical panels, one way is to put a full perspex sheet over the whole guts secured by screws at the corners.Last edited by EddyCurrent; 13-11-2013 at 05:35 PM.
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
