Thread: Ready Steady Eddy
15-11-2013 #10
Yes Agree in industrial situation then machine needs to be safe and Regs followed to keep the HSE police happy but mostly folks here are DIY and there's world of difference between Reg compliant and being used safely in a shed.!! . . . Practical common sense is all that's needed IMO.
Regards Strategy's then here's my take.!! (which has changed over the years.! I used to kill everything regardless)
E-stop means Foooooooking Hell EVERYTHING STOP NOW.!! . . . So Strategy 1 only.!
Limit/s trip means machine is outside it's working parameters so do something about it.!! . . So disable the drives using the drives enable signal, Not killing power to drives so maintaining holding torque. At same time inform the Control software so it's halts program execution.
Send Stop signal to Spindle/VFD again leave power on has it's not an emergency, it's a machine position error so we just need it to come to a controlled stop.
Along side this you could if wanted turn off other things like vacuum etc either by informing control software or by locally controlling on/off thru Relays but all this should just be on the Limit circuit NOT The E-stop.
Same regards the Fault signals from drives, It's a machine Error not an emergency so same applies just stop the machine in a controlled manner.
If any of the above happens then it should be wired in such away that some form of Latch is dropped and not allowed to re-latch until fault is cleared and then only with Push of a Momentary button not Reset switch.
The E-stop should have ultimate control and Kill power to everything in the event of an emergency so all Latches are dropped and won't reset or start again without some input. Ie Pushing Reset momentary button.
Charge pump and over Temp etc are again machine errors not emergency conditions so just bring machine to stop in controlled manner.
Personally I wouldn't have Temperature control anything over than alert the user thru audible or Visual means. Problem comes from the manner in how the machine is stopped.? To safely stop the machine and not wreck the work piece or lose position requires a Feed hold not a Stop command.! If you stop the machine while it's moving, either thru E-stop, limit trip/machine error or just pushing Stop button on control screen then you MUST presume you have lost position thru inertia pushing, THE ONLY SAFE WAY to bring the machine to stop and not lose position is to use Feed hold and allow the control software to do a controlled stop.
Problem with this is it's doesn't do it instantly so there's always some delay until look ahead buffer is cleared or it's finished the current move. If you have an overtemp problem you won't want to wreck the job so a controlled stop is required so feed hold must be used.
It is possible to use an input and have Mach watch it then use an OEM trigger to activate the Feedhold if the state changes but personally I wouldn't and just have a Spindle siren scream at me.!!
This also answers your "Stop Button" option.! . .Pressing stop will only stop the machine and other attached devices in a semi controlled manner but it won't be controlled and can't reliably be resumed from without first homing the machine to get back into position.
Also noted you said Home limit's.? Home switches are not limits of any kind neither are they part of any system, e-stop or limit etc. They solely define the Machine coordinate Zero position and are purely input's to the Control system and nothing else..!! . . . .(Eddy I know you probably know this but others may not)
There are currently 17 users browsing this thread. (0 members and 17 guests)
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
