I'm thinking this is going to be my Charge Pump relay circuit. My BOB ENA signal is active low so the relay will be in the 'healthy' state when de-energised, this is not fail safe and I could have inverted the signal but it's going to do. The BOB is supplied by 24vdc and so GND is common to the 5v and the 24V.
You have C and E swapped over. Its an NPN so E is always to -ve rail.
with only 3 or 4 more components you could make it failsafe and i would...
