Thread: Ready Steady Eddy
03-07-2014 #301
Ive been aware of this thread for a while, but tonight, only just read it.
Nice Design!!!. Must say, hats off to you much better than mine. I think every single thing I wished I did with mine you have done here... Proper Rails, I like the extra plate at the top of the Y carriage (making a figure 8) The X steppers inside the gantry (rather than sticking out). and the general quality of the build looks superb
Credit to you chap. Got to start thinking about my next build soon...
The Following User Says Thank You to kingcreaky For This Useful Post:
04-07-2014 #302
Sorry my friend, but that is not correct. I didn't think so when I read it, so I just went out to the garage to check. My machine has a lot of flex, so I can easily rack the gantry one way or the other. I have dampers on my steppers, so with the power off, I can move one side by turning the dampers.
First I moved the master side about 3mm away from home, then powered up the machine, and homed the X axis. The slave axis hits the switch, and backs off, while the master keeps moving to it's switch, then it backs off.
Next, I moved the slave side 3mm farther from home. This time, the master hits the switch, and backs off, while the slave keeps moving.
Each side of the gantry (master and slave) move independently to their own switches. For all practical purposes, they are not slaved during homing.
Yes, but technically, no. The Home position is not set when the switch activates, but when it deactivates as it's backing off. So technically, the switches need to be set so that they both deactivate when the gantry is square1. Do both X home switches have to set so they both activate together exactly when the gantry is at the physical 'square' position ?
Yes, but as Jazz said, even cheap switches are quite accurate. The DIY Hall switches I use are supposed to ba accurate to about .01mm or better, and only cost about $3 each to make them. The most important factor is accurately positioning the switches.2. If so, we are now relying on the repeatability of the switches for machine accuracy.
The side that hits the switch will back off and stop, while the other side continues to it's switch, squaring the gantry.3. Imagine a cutting job has just been completed so that the gantry has been up and down loads of times and it's now out of square. When it comes back to the home position it will hit one home switch first, so then what happens ?
Depending on the type of switch, you may or may not actually see the machine back off the switch. On my machine, it backs off such a small amount that it appears to just stop.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
04-07-2014 #303
To be honest Gerry I wasn't 100% sure my self it worked like I said and couldn't can't check as I don't have slaved motors on my machine. Last machine I setup that used slaved motors was several weeks ago and was using the ESS but I'm sure that stopped both motors and backed off then moved slave.? Thou I'd have to check again to be 100%. I don't ever use PP so can't check if it works differant to Motion control cards but I will on next slaved machine I'm building just out of curiosity. Previous machine also used Motion control card but that was Russian PLCM and thought that did the same but again can't be 100%.? Esp as it happens so fast and with gantry being square so hard to see.!
But more the point was they work together to square the gantry and like as been said if the gantry's setup square to start with and switches located at same point it's a seamless operation and very little twisting forces applied if correctly setup.
Edit: One other thing for clarity for others (Gerry knows this ).? The speed at which you home makes a big difference to accuracy and how far it over shoots then as to backoff. Thick of it as driving wheels upto a line in your car.! At fast speed chances are you'll over shoot further then have to back up more to put wheels on line. Same principle go slower and chances are you'll hit the line ever time with little to no over shoot.Last edited by JAZZCNC; 04-07-2014 at 01:54 AM.
04-07-2014 #304
Homing in motion controllers is done differently than with the parallel port, so you may be correct with the SS. I know it's taken several years for Greg to get slaved homing to work correctly with the SS.
Gerry
11-07-2014 #305
11-07-2014 #306
11-07-2014 #307
Surge protectors here, the one with RJ45 support. Though allot are wifi''ing it up now days.
.MeLee
17-07-2014 #308
Going back a little here to homing but was looking thru Mach manual today and noticed this in the Homing/limits section.
"When a Reference operation is performed, then the axes will run together until the final part of referencing, which
is moving just off the Home switches. Here they will move so that each stops the same distance off its
own switch. Referencing will therefore correct any racking (i.e. out of squareness) of the gantry, which
might have occurred when the machine was switched off or because of lost steps."
So they do a mixture of both really has they are slaved upto point it's backing OFF the Switch.!! Tonight Just checked on machine that is using PLCM-E3 and it works just like this. . . . . . Just thought this might clear any confussion.
18-07-2014 #309
So after that bit of RTFM, here's how I would set up the homing switches;
Assuming 2 home switches used on X
1. One switch can be mounted in a fixed position while the other switch needs to be + and - adjustable in the X direction.
2. Using some form of measuring equipment e.g. large T square, set both switches square to the X axis.
3. Carry out a homing operation of the machine then using the same measuring apparatus as in step 2. check squareness of the gantry to X axis
4. If the gantry is not square then move the adjustable home switch by the required amount and in the required direction.
5. Repeat steps 3 and 4 until the gantry is square to the X axis.Last edited by EddyCurrent; 18-07-2014 at 09:33 AM.
18-07-2014 #310
Eddy Spot on, simples, can't just remember if the slave needs to be the adjustable one. I drilled some holes down the x and y then put dowels in then the square against the dowels. then readjusted the switch and tried again. ..Clive
There are currently 12 users browsing this thread. (0 members and 12 guests)
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
