Thread: Ready Steady Eddy
12-11-2014 #321
12-11-2014 #322
The creative adult, is the child who survived
12-11-2014 #323
@ba99297, wrong thread my friend, I've done it myself so no worries.
13-11-2014 #324
Sorry Eddy!!!
18-11-2014 #325
Since using the latest Smooth Stepper plugin for several weeks, months ? I've had no problems with homing the X and slaved A drives, I would say that issue is now sorted.
ESS_v10r2d1d.zipSpelling mistakes are not intentional, I only seem to see them some time after I've posted
19-11-2014 #326
And it only took them ~5 years to get it right.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
19-11-2014 #327
07-12-2014 #328
Proposed modifications !
This is to allow joints to be cut in the ends of wood, it provides a 'hole' of roughly 200mm square so the wood can be placed in the X or Y planes.
It's based on using this vice guts; http://www.canadiantools.co.uk/tools...19.html#SID=50, the rest is made from various types of wood (normal for this type of vice
Made so it's removable with a replaceable insert to put the bed back to normal.
Pictures show how it looks with vice fully open and fully closed.
I can't have the vice sticking out at the front so the only thing to confirm is whether I can hold a piece of wood in the jaws while tightening the vice.
There's more than enough room above for the spindle and tooling.
Edit:
Would this do instead ?
07-12-2014 #329
Interesting idea and a good price for that vice if memory serves. I can't help feeling that while I think this will work it's going to be a lot of hassle to set up for the benefit it brings unless you are intending to make a run of identical components. For the joint to be any good you'll need to get the wood bang on parallel with the cutter (in the vertical direction) which will be difficult without a fence which would have to stick down though the table.
I think I'd invest my time in buying a Festool Domino (amazing bit of kit) and if I wanted dovetails a dovetailing jig.
07-12-2014 #330
Thanks for feedback.
The corner innermost to the machine will be made very accurate so that any wood placed up against it will be vertical in both planes. The whole assembly would be securely fastened to the bed using location points to give repeatable positioning.
Domino's too big for my purpose and also too expensive. Need more joints than just dovetails, the vice would allow wood to be angled at 45 deg. for example.Last edited by EddyCurrent; 07-12-2014 at 07:45 PM.
There are currently 16 users browsing this thread. (0 members and 16 guests)
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
