15-09-2013 #7
Depends on the closed loop system, if your talking servo system then you'll need a controller that supports closed loop. Common DIY controller is MACH3 and that won't do closed loop.
If your talking about the Lead shine closed loop Hybrid stepper system then yes this will add to any machine has the drive takes care of the closing the loop so can work with any controller.
It's mainly to do with Duty cycle, meaning how long it can run without rest. WC spindles are 100% duty cycle and can run for days none stop, i've run mine 34+ hrs without stopping. This can be important if your doing large or very detailed 3D work that have tiny depth of cut or tiny step over, often both if high quality finish is required.
They are also much quieter than air cooled has they don't have a noisy fan to do the cooling.
Ah ah ye bit out the DIY range we thinks.!! . . . . If you have used or experience on a Datron M8 then your going to be sick with the offerings £1500 will get you that's for sure.!!Last edited by JAZZCNC; 15-09-2013 at 01:22 AM.
Milling Machine Advice
By Washout in forum Milling Machines, Builds & ConversionsReplies: 28Last Post: 29-07-2014, 10:03 AM -
Need advice for a new machine?
By az786again in forum General DiscussionReplies: 7Last Post: 05-03-2014, 02:04 PM -
Advice about a sentence concerning CNC Machine!!!
By hoezap in forum General DiscussionReplies: 5Last Post: 09-11-2011, 02:25 AM -
cnc machine buyers advice
By wyndham in forum Marketplace DiscussionReplies: 0Last Post: 29-06-2011, 06:52 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
