Thread: Advice on spindle inverter spec
I once bought a panel with KEB drives. The local agent said he could download the parameters if I took the drive to him. Unfortunately they had a 3 phase input so I could not use them at home. Any drive of the rated capacity should work. Just check if the motor has a star/delta connection for 220v 3phase input depending on your supply. The v series from Yaskawa are very good and they used to have a plant in Scotland.
15-09-2013 #2
15-09-2013 #3
15-09-2013 #4
15-09-2013 #5
Just get an inverter based on motor current and voltage and the input voltage you require e.g. 240v single phase. I have found these people very good
AC Inverter Drives (230V) (Page 1 of 43)
The motors shown are slightly odd in that they are 200v and 185v when connected in 'star' as shown on the rating plate, normally a motor would be 230v when connected in 'delta' and 415v in 'star'.
Obviously these are bespoke motors.Last edited by EddyCurrent; 15-09-2013 at 09:48 PM.
Confirming PSU spec for steppers.
By Rogue in forum Stepper & Servo MotorsReplies: 103Last Post: 13-01-2014, 12:37 AM -
50/60 volt spindle inverter.
By GEOFFREY in forum Spindles & Drive MotorsReplies: 0Last Post: 24-12-2012, 03:58 PM -
Water cooled chinese spindle collets, Advice from owners please
By craigrobbo in forum Generic Chinese SpindlesReplies: 15Last Post: 11-05-2012, 12:08 PM -
FOR SALE: 2.2KW Water Cooled Spindle + Inverter (yes the Chinese one!)
By Bokoshoko in forum Items For SaleReplies: 3Last Post: 06-02-2012, 12:43 PM -
System spec and Mach3
By gorbo in forum Computer HardwareReplies: 5Last Post: 23-01-2011, 03:25 PM
