Thread: Driver & Driven
15-09-2013 #3
It all depends what gear ratios you want to achieve. Generally speaking, a direct drive system would use either Oldham Couplings or drive pulleys of the same diameter. For increased torque and slower speed, you need to use a smaller pulley on the motor (or a larger pulley on the leadscrew).
Incidentally, notice I linked to HTD5 pulleys above? I bought T5 pulleys and then discovered the belts are pretty expensive. The HTD5 pulleys are (apparently) a better choice as they will have less backlash and are easier/cheaper to get hold of.
The Following User Says Thank You to birchy For This Useful Post:
stepper motors not being driven
By sprint in forum Machine Control SoftwareReplies: 4Last Post: 12-02-2013, 03:42 AM -
2 Motors driven from one driver in parallel
By fozziebear40 in forum Motor Drivers & ControllersReplies: 5Last Post: 12-07-2012, 09:22 AM -
NEW MEMBER: marker pen driven over an 8x4 sheet help.
By Danny in forum New Member IntroductionsReplies: 40Last Post: 02-12-2011, 12:45 AM -
BUILD LOG: 8020 belt driven 3 axis
By compfranon in forum DIY Router Build LogsReplies: 20Last Post: 30-03-2010, 05:06 PM -
BUILD LOG: Belt driven 3 axis machine
By Swarfing in forum DIY Router Build LogsReplies: 14Last Post: 21-02-2010, 10:46 PM
