    Lives in East Lothian, United Kingdom. Last Activity: 9 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    That would apply if I was changing the frequency, however for this application the frequency would be fixed at 50Hz when powered, although it would need to ramp up/down when powered on/off, but that could be set to a minimal amount.
    Transformer VS output filter in VFD and motor connection
    Some of the ideas posed in forums etc. have not been tested widely because in industry for example there would be no requirement as all the required voltage supplies and associated equipment are available.
    I've used inverters with output chokes for long cable lengths but have not seen them used with a step up transformer, but that doesn't mean to say it's not done.
    You must of used similar google terms to me, as I've already seen that page.
    Ideally I'd like to get my hands on one of the digital phase converters, but I really don't want to pay the price tag to get one!
  5. The vfd is not a three phase supply. It is designed to drive a motor only.
    If you add in a transformer into the mix , it change the phase of voltages and currents that the vfd monitors and controls .
    If you're looking for a simple answer to powering a 3ph machine from single phase then a rotary converter would probably be your best option.
    Bill
    Quote Originally Posted by BillTodd View Post
    Bill
    This is even more true with a vector drive as it 'talks' to the motor as it were to fine tune it's parameters and estimate the rotational state of the rotor.
    I already have an RPC, it's just that I'm considering an upgrade, and I'm curious as to how certain companies are creating digital converters with what appears to be a bog standard VFD.
  1. NEW MEMBER: i didnt think i was stupid but i do now!
    By stone in forum New Member Introductions
    Last Post: 17-03-2013, 08:49 PM
  2. Stupid question I know... but - What size is my Spindle Collet ?
    By Fivetide in forum Milling Machines, Builds & Conversions
    Last Post: 25-11-2012, 03:34 PM
  3. Chip load chart
    By motoxy in forum Machine Discussion
    Last Post: 17-09-2012, 10:05 PM
  4. How to pre load screws
    By graham4877 in forum Lead Screws, Nuts & Supports
    Last Post: 14-08-2012, 11:07 AM
  5. VFDs?
    By graffian in forum Motor Drivers & Controllers
    Last Post: 30-06-2010, 04:42 AM
