You must of used similar google terms to me, as I've already seen that page.
Ideally I'd like to get my hands on one of the digital phase converters, but I really don't want to pay the price tag to get one!
16-09-2013 #2
The vfd is not a three phase supply. It is designed to drive a motor only.
If you add in a transformer into the mix , it change the phase of voltages and currents that the vfd monitors and controls .
If you're looking for a simple answer to powering a 3ph machine from single phase then a rotary converter would probably be your best option.
Bill
16-09-2013 #3
16-09-2013 #4
I already have an RPC, it's just that I'm considering an upgrade, and I'm curious as to how certain companies are creating digital converters with what appears to be a bog standard VFD.
17-09-2013 #5
Looks like you're question has been answered - it's not going to work, at least not directly.
A 'vector drive' (i.e. one that uses the field oriented control algorithm) senses a number of the phase currents and uses these to infer the position of rotor, it's field and the stator field. The controller then frequently modifies the currents to ensure the stator and rotor fields are always perpendicular, as this gets the most torque. It's hard to sense the motor phase currents accurately with a transformer in the way... There are plenty of other reasons not to do this, e.g. the transformer adds another time constant to the system.
The basic power electronic circuit to convert from a fixed frequency supply to a single one is just a 3-phase bridge generally made from IGBTs. This circuit is used in all sorts of appliances, what differs is how it's controlled, so take a 'bog-standard' VFD, remove the control circuit and make your own, then (within reason) you can put whatever you want on the output. That's why for instance you can now get motor drives which can control induction motors and synchronous motors - the basic circuit inside them is the same, it's the control that differs.
NEW MEMBER: i didnt think i was stupid but i do now!
By stone in forum New Member IntroductionsReplies: 12Last Post: 17-03-2013, 08:49 PM -
Stupid question I know... but - What size is my Spindle Collet ?
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 17Last Post: 25-11-2012, 03:34 PM -
Chip load chart
By motoxy in forum Machine DiscussionReplies: 1Last Post: 17-09-2012, 10:05 PM -
How to pre load screws
By graham4877 in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 14-08-2012, 11:07 AM -
VFDs?
By graffian in forum Motor Drivers & ControllersReplies: 9Last Post: 30-06-2010, 04:42 AM
