16-09-2013 #5
First question:
It depends on lots of factors, but mainly the diameter of the tool and how fast you want to cut with it. If that motor is 2-pole (just under 3000rpm) then 750W is enough power to cut steel but not quickly, depending on your definition of quickly. The maximum tool diameter will be limited since the motor will output (approximately, depends on the drive) constant torque over the speed range using a VFD. Bear in mind though that since the output power is simply torque multiplied by speed (angular velocity strictly speaking), your available power will reduce linearly to zero with reducing speed, so at 1500rpm you get about 375W, etc...
Also, if you need to use over 3000rpm then it's generally safe to run the motor on a higher frequency to get higher speed, maybe 5k-6k.rpm (do research this before trying as there's more to it), but again the power will drop linearly with increased speed. One way round this, which John S has done, is to get a company to rewind the motor for 6000rpm, then you will get more power. Or if you're keen, rewind it yourself ... although I've not tried it yet, I'm confident that it's not difficult to do.
2nd question:
You'd either have to use very small tools, or tools with a special coating (Cut-well 'blue' tools are allegedly good) to enable the spindle to still be run at fairly high speed. As above, your problem is the output power drops with speed, so at 3000rpm the motor might only output about a sixth of the rated power. That's still 500W though, so it may be enough. Have you got a link to the motor you have in mind?
Edit: Are you concerned about the weight of the spindle motor? I wouldn't be as for any machine able to do a good job of cutting steel the mass of the motor will be a tiny fraction of the machine as a whole.Last edited by Jonathan; 16-09-2013 at 11:49 PM.
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Stepper Motor Power Question
By boldford in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 17-07-2012, 09:40 AM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
Calculating Stepper Motor Power? Strength?
By antsals in forum General DiscussionReplies: 2Last Post: 11-07-2011, 12:18 PM -
FOR SALE: Servo motor with 26:1 Gear box, EPOS controller and Power shunt unit
By Jimmybristol in forum Items For SaleReplies: 1Last Post: 30-05-2011, 11:03 PM
