    Lives in East Lothian, United Kingdom. Last Activity: 9 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,989. Received thanks 373 times, giving thanks to others 9 times.
    What's currently available for calculating pulley spacing/belt sizing?
    Or, if somebody happens to have some already installed, and willing to run a few calcs, I currently have a 10:20 L(3/8" pitch) setup linked with a 150L (40tooth 15"/381mm) belt.
    I'm wanting to change to a 16:20 set-up, and need to know the difference in centre distance between the pulleys using the existing belt, and the next commonly availble size up which would appear to be a 187L (50tooth) belt.
    Thanks!
    Try my spreadsheet:
    http://www.mycncuk.com/forums/machin...t-lengths.html
    Changethe 'Belt pitch' to 9.525mm and it'll work.
    Thanks for that.
    15mm nearer for the same belt, or 30+mm for the longer belt. I'll need to do some measuring in the morning.
    Edit: Ooops ! wrong thread, please ignore.
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 3 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
  1. Making timing pulley - putting theory into action
    By wiatroda in forum Metalwork Project Showcase
    Last Post: 28-11-2011, 02:22 AM
  2. Increasing timing pulley bore size from 3mm t0 3.175mm
    By divdav in forum Gantry/Router Machines & Building
    Last Post: 14-05-2011, 09:45 AM
  3. 4th Axis timing pulley + Axminster bandsaw review
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 09-04-2011, 07:31 PM
  4. help needed drilling bore hole in mxl timing pulley
    By geekinesis in forum Gantry/Router Machines & Building
    Last Post: 02-02-2011, 01:07 PM
  5. WANTED: Timing Pulley Suppliers?
    By m_c in forum Items Wanted
    Last Post: 02-11-2008, 01:02 AM
