What's currently available for calculating pulley spacing/belt sizing?
Or, if somebody happens to have some already installed, and willing to run a few calcs, I currently have a 10:20 L(3/8" pitch) setup linked with a 150L (40tooth 15"/381mm) belt.
I'm wanting to change to a 16:20 set-up, and need to know the difference in centre distance between the pulleys using the existing belt, and the next commonly availble size up which would appear to be a 187L (50tooth) belt.
Thanks!
18-09-2013 #2
Try my spreadsheet:
http://www.mycncuk.com/forums/machin...t-lengths.html
Changethe 'Belt pitch' to 9.525mm and it'll work.
18-09-2013 #3
Thanks for that.
15mm nearer for the same belt, or 30+mm for the longer belt. I'll need to do some measuring in the morning.
12-04-2014 #4
Edit: Ooops ! wrong thread, please ignore.
12-04-2014 #5Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
Making timing pulley - putting theory into action
By wiatroda in forum Metalwork Project ShowcaseReplies: 15Last Post: 28-11-2011, 02:22 AM -
Increasing timing pulley bore size from 3mm t0 3.175mm
By divdav in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 14-05-2011, 09:45 AM -
4th Axis timing pulley + Axminster bandsaw review
By Jonathan in forum Metalwork Project ShowcaseReplies: 4Last Post: 09-04-2011, 07:31 PM -
help needed drilling bore hole in mxl timing pulley
By geekinesis in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 02-02-2011, 01:07 PM -
WANTED: Timing Pulley Suppliers?
By m_c in forum Items WantedReplies: 4Last Post: 02-11-2008, 01:02 AM
