    Thanks richie00boy, that is really good to know - how did you choose an eBay seller to buy from?
    Just seen that there's a complete setup in the for sale section, only a couple of hundred more than a new eBay machine and you get a ready to run system with PC and Mach 3. Would get you started cutting PCBs straight away and because you like upgrading would be (by all accounts!!) perfect
    Neil...
    Build log...here
    My first machine was self built from scrap printer parts (& thin scaffolding type piping would you believe!) - unsurprisingly, it sucked, but it could at least do simple through hole pcbs.
    my next machine was imported from Taiwan....surprisingly solidly built but didn't have ballscrews (just simple M10 rod)....a lot better, but nesting (many copies of the same pcb) was not possible ....backlash issues meant that if you cut all the tracks for say 3 pcbs first, when you came to drilling run, the holes wouldn't align with the tracks!)
    If you're serious about accuracy & want to be able to do many copies of the same PCB in one session, then I'd strongly suggest that you buy a machine with ballscrews .....the Z suffix on the chinese cnc machines are normally the ones that have ballscrews (therefore 3040Z etc, for example - 2013 Updated CNC 3040Z-DQ 3-Axis Engraving Machine Router Set Mill Device cmh | eBay ...though be aware that the stepper driver boards on these chinese machines are awful & prone to very early problems/failure). I'd be inclined to instantly sell the control box (to someone who no doubt has one that blew up) & put the money towards some m542 drivers...http://www.ebay.co.uk/itm/CNC-Micro-...item27c7454753
    For milling PCBs (& all the other materials you mention) I personally have a strong preference for fixed gantry CNC machine (of which there are zilch in the 3040 sizes available on Ebay) & would look at importing one.... http://cnredsail.en.alibaba.com/prod..._aluminum.html - that one is about $1200 delivered + taxes (which would probably result in a final 'to your door price' of £1100)
  4. The Following User Says Thank You to HankMcSpank For This Useful Post:
  5. #4
    Quote Originally Posted by njh View Post
    It's easier than you think. There were basically two machines, the 3020 type with moving gantry and the sable type with moving table. I chose the 3020 type as it took up less desk space and a recommendation for this type came from a mate who worked with very high end CNC machines, can't remember now what his reason was though. Then I just chose the cheapest seller who shipped from the Portsmouth warehouse. There is no difference between sellers, they are all just drop shippers for the Portsmouth warehouse.
    Quote Originally Posted by HankMcSpank View Post
    I'll have to see if that becomes an issue when I use the machine for bigger jobs. I priced up ballscrews recently and I think I could convert the X and Y axis for about 50 quid.
    I do hear a lot of people saying the controller you get is rubbish, but touch wood mine seems OK despite some errors on my behalf not setting it up correctly, which may have stressed it more than normal. That is the one thing I was lucky with, got a mate to help me set it up as settings provided by the seller were not right.
    I can let you have the settings file if you need it, should you buy the same machine.
  6. The Following User Says Thank You to richie00boy For This Useful Post:
  7. #5
    Thanks for the advice HankMcSpank and richie00boy
    Searching for ball screw in the title/description or 3040Z really reduces the result set. Think I will probably go for a ballscrew from the start.
    It looks like the newer/'updated' models have a black control box, like the ones on Yoocnc 3020 3040 6040 series - carving-cnc.com. Some even have YOOCNC written on them in the pictures.
    Good to know that I should expect to want to / need to replace the stepper driver boards at some point.
  1. Replies: 2
    Last Post: 20-04-2014, 05:19 PM
  2. thinking about this Syil X5plus CNC Milling Machine with 4th Axis
    By Dellboy in forum Marketplace Discussion
    Last Post: 22-04-2012, 05:52 PM
  3. Machine Buying advice
    By jrob3rts in forum Marketplace Discussion
    Last Post: 17-09-2010, 04:59 PM
  4. opinions on buying cnc milling machines
    By DGH in forum Milling Machines, Builds & Conversions
    Last Post: 27-05-2009, 04:47 PM
