    Hi guy,
    I am interested if anyone would be will to quote my project. I require someone with a 3-axis CNC router who can mill.
    The project -
    I want to make a logarithmic spiral, (like a snail), from Boltic Birch Plywood - 40mm thickness. I have worked out and completed the design. It consists of 102 sections which are hollow cylinders with an angled top. Each section has a different diameter ranging from 48.5mm to 238mm. The heights range from 13mm to 38mm and the angles ranging from 5 degrees to 15 degrees.
    The design is completed, the disks have been nested for a ply sized 1200*2500. The file is an .STL ready for CNC routing.
    A vacuum table or clamping shouldn't be required. I have designed the cut-outs to have a top and bottom tab, so that the disk remain attached to the board when routing.
    Please see images.
Name:	Random sample cross sections.jpg
ID:	10182Click image for larger version.
Name:	CNC nesting.jpg
    Hi Guy's, I'm still interested in getting my projected quoted. If you price is a fair and can be justified I would be grateful.
    hi have you got programme for it?
    Sorry, I am not sure if I understand you question. The design has been on solid works and the .STL files are ready to upload.
  1. Got a quote for £7k can I make it for £500?
    By Gtee87 in forum Gantry/Router Machines & Building
    Last Post: 24-02-2014, 02:42 AM
  2. RFQ: quote to cut some ali gantry sides
    By D-man in forum Projects, Jobs & Requests
    Last Post: 26-10-2012, 10:21 PM
  3. RFQ: Wondering if it's possible to get these CNCd and looking for a quote
    By steventhebrave in forum Projects, Jobs & Requests
    Last Post: 07-12-2010, 03:45 PM
  4. Does this quote seem reasonable?
    Last Post: 02-03-2010, 10:21 AM
