  1. #3
    I'm no electrickery expert but have experience of similiar things and it could be high EMF getting introduced on the drive power line and because your using linear psu's they protect them selfs from returning currant. The drives will try to pass any extra currant back but if can't go anywhere they will protect them self and fault. (Or blow up if too high)
    At worst electromagnetic interference is only going to add well under a volt to improperly shielded cables. That's not enough to damage the drivers due to overvoltage, since the voltage they output is substantially greater. Also, the drivers are optically isolated, so no matter what you do to the motor side it's not going to harm the breakout board.
    Having said that, it's a bit strange that a red fault light is showing. Assuming that's on one of the drivers it's most likely caused by a dodgy connection somewhere on the motor. That or it could be that the power supply you're using isn't regulating the output properly, since these drivers do apparently have protection against over and under-voltage. I tend to agree that if you want to start buying things, getting or making a better power supply would be your best bet. But check the wiring first as that's more likely...
  1. 3 wire stepper motor drivers?
    Last Post: 17-08-2013, 10:01 PM
  2. Help Make 1st Step - Wiring Up Drivers to Motor and Arduino
    By Treemonkey in forum General Electronics
    Last Post: 25-04-2013, 05:47 PM
  3. Setting up stepper motor drivers
    By croy in forum Motor Drivers & Controllers
    Last Post: 30-09-2012, 09:51 PM
  4. eBay Stepper Motor Drivers from China
    By Mad Professor in forum General Electronics
    Last Post: 20-07-2009, 10:54 PM
  5. Motor controllers/drivers/wire ?!?
    By Lee Roberts in forum Motor Drivers & Controllers
    Last Post: 24-08-2007, 08:46 PM
