Hi guy,
I am interested if anyone would be will to quote my project. I require someone with a 3-axis CNC router who can mill.
The project -
I want to make a logarithmic spiral, (like a snail), from Boltic Birch Plywood - 40mm thickness. I have worked out and completed the design. It consists of 102 sections which are hollow cylinders with an angled top. Each section has a different diameter ranging from 48.5mm to 238mm. The heights range from 13mm to 38mm and the angles ranging from 5 degrees to 15 degrees.
The design is completed, the disks have been nested for a ply sized 1200*2500. The file is an .STL ready for CNC routing.
A vacuum table or clamping shouldn't be required. I have designed the cut-outs to have a top and bottom tab, so that the disk remain attached to the board when routing.
Please see images.
Name:	Random sample cross sections.jpg
ID:	10182Click image for larger version.
Name:	CNC nesting.jpg
