Residual Stress in Glass - Mystery of Prince Rupert's Drop at 130,000 fps
Mystery of Prince Rupert's Drop at 130,000 fps : Ri Channel
Fellow geeks on the forum may find this interesting. As demonstrated, the very high residual stress within the bulbous end of the drop allows it to withstand a blow from a hammer. However, a slight touch on the drop’s tail will cause the whole structure to explode.
The Following User Says Thank You to AndyGuid For This Useful Post:
26-09-2013 #2
Nice one. There are some good slow motion videos here:
theslowmoguys - YouTube
26-09-2013 #3
Very interesting!
The same principle(though less extreme) is used to toughen, or temper, flat glass.
Heat to around 650 deg c , then rapidly cool with blasted air creating tension inside the glass.
Toughened glass is stronger than normal glass (the name's a giveaway!), but is susceptable to defects or impacts from sharp pointed implements.
One of the principle benefits is the fact it breaks into lots of small fragments that are much safer than annealed glass.
24-11-2013 #4
Then you just have to watch this by the same guy on the Worthington Jet -
Just love the "Number 2 version" of the projectile and the Question/Response
Q) Are those beads?
A) Technically
Poop Splash Elimination - Smarter Every Day 22 - YouTube
the mystery of the wonky corners
By kingcreaky in forum Machine DiscussionReplies: 19Last Post: 06-05-2014, 03:58 PM -
mystery motor??? what is it for???
By jonnydeen in forum General ElectronicsReplies: 10Last Post: 20-07-2012, 12:19 PM -
Cutting/Milling Glass?
By Tenson in forum Machine DiscussionReplies: 1Last Post: 12-04-2012, 10:10 PM -
Machining, fabrication and engineering services available...just drop me a line!
By Hi-Spec in forum Opportunities Available & SoughtReplies: 0Last Post: 09-04-2012, 08:52 PM -
Mystery Profile, Please Help!
By floydpjasper in forum Machine DiscussionReplies: 3Last Post: 10-03-2012, 06:27 PM
