Thread: Which Belt Profile
Hi all.
I am converting my Milling machine to CNC. I have decided that due to the Milling head being v. heavy to use a drive belt on the Stepper motor @ 3:1 ratio, ie. 20 TPI on the Stepper & 60 TPI on the spindle. My question is this, in view of the myriad of choices, what do the forum members recommend by way of profiles, AT,T,STD,HTD,3mm or 5m pitch.
Were is the best / cheapest place to buy this equipment ?
Your help would be highly appreciated.
Regards
Ray
27-09-2013 #2
Most people use HTD belts.
Bearingstation are the cheapest place I know of in England, but lately you'd probably get them quicker if you ordered from aliexpress! There's also Belting Online, who offer a boring and tapping service for the pulleys, which may be worth the small extra cost if you haven't got the means to do this, i.e. a lathe and milling machine.
The Following User Says Thank You to Jonathan For This Useful Post:
27-09-2013 #3
27-09-2013 #4
27-09-2013 #5
what width of belt is best? and is it better to have a longer pulley on either the motor or the screw? or does this not matter?
The Following User Says Thank You to jcb121 For This Useful Post:
27-09-2013 #6
The width depends on what you're doing, but in general 15mm wide is fine. If it's a long belt then increasing to 25mm is a good idea as it will raise the stiffness.
By longer I think you mean the width of the pulley? If so, you generally just want pulleys which are nominally the same width as the belt. In reality the pulleys are slightly wider, so there is some clearance between the belt and pulley flanges. The main thing is to make sure the pulleys are aligned axially, so the belt isn't rubbing against the flanges.
P.S. There are many threads discussing this on the forum.Last edited by Jonathan; 27-09-2013 at 12:56 PM.
So what to do with this profile?
By Rogue in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 25-09-2012, 09:03 PM -
Belt drive on a router
By John S in forum Rails, Guideways & BearingsReplies: 23Last Post: 10-09-2012, 09:39 PM -
NEW MEMBER: profile
By luke11cnc in forum New Member IntroductionsReplies: 1Last Post: 25-07-2011, 07:48 PM -
Belt Driving your leadscrews !
By Lee Roberts in forum Lead Screws, Nuts & SupportsReplies: 11Last Post: 05-02-2011, 09:14 AM -
Timing belt instead of rack!
By ptjw7uk in forum Belt Drive, Pulleys & TimingReplies: 8Last Post: 18-12-2009, 12:49 PM
