04-02-2014 #22
You shouldn't use a resistor between earth and neutral.
If it's a linear power supply this implies a transformer, rectifier, capacitor, setup and there is no problem connecting both primary and secondary to earth because they are not electrically connected, they are connected magnetically through the transformer metal core.
You are correct about some people connecting the -ve to earth and some don't, it's the same with 110v control transformers in larger installations.
One thing about having one pole to earth is that if there is an earth fault on the other pole it will blow the fuse but if one pole is not earthed the fuse will not blow because there is no circuit. In the second instance two earth faults have to be present, one on each pole before the fuse blows, it's then the same as shorting the poles together.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
Custom power DC supply
By M250cnc in forum Electronic Project BuildingReplies: 11Last Post: 22-11-2010, 09:48 PM -
power supply problms
By Scott in forum General ElectronicsReplies: 13Last Post: 11-07-2010, 12:58 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
