    I've not seen this mentioned but sometimes it's hard to find specific info here. I thinking about using one limit switch per axis, so take the Z axis for example, you mount a switch at the mid travel point on the Z 'fixed' backplate, then you position 2 strikers near each end of the Z 'moving' plate, these would have slotted brackets to allow adjustment. Now when the Z axis reaches either end of it's travel one of the strikers will activate the limit switch. Obviously same goes for X and Y and the switch could be mounted on the moving part instead if that was more suitable.
    Any opinions about this ?
    First it depends on the encoder on the axis -Absolute meaning it knows were it is at power on or the other that requires the machine to be sent to home position/reference at start up ----these have to be very accurate switches and usually are plunger type -------Home position is found using the switch but a seperate dog is used for plus and minus over travel protecting the ball screw ends from being crashed into
    I won't be using encoders, absolute or incremental, I'm just talking about physically activated switches or proximity type. I will be using separate switches for homing mainly because I will have a slaved stepper that I believe needs it's own homing switch for squaring up the gantry.
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Single switch per axis is fine.
    Often the number of switches per axis is more to do with convenience than anything else.
    We used this method on overhead cranes and other reciprocating machinery, it's just that whenever limits are mentioned in regard to cnc machines they always talk about 2 switches per axis.
    Yes it works fine many milling machines use this method.
    Edit: You can still wire them in series has well.
    That's the method I'll use then, I thought I would get the electrical drawings done, get some stuff ordered, put it together, while waiting for items from China.
    I'm going for an Ethernet Smooth Stepper, probably AM882's, but still pondering the best bob for this combination.
    Usual CNC setup with homing required machines
    Move to Zero
    Plus soft limit--- where the servo is stopped or held mode is plus 5mm and comes from the axis control
    Hard limit activated by a switch linked to the Estop circuit is plus 10mm
    The same goes for the Minus side
    Wither its two switches or two position dogs really doesn't matter but they are there to protect the machine and zones
    For recovery from these usually needs an over travel release button on the operators panel and sometimes keyed so proper- questions are ask to why its there in the first place
    Quote Originally Posted by Ulsterman View Post
    Normally wired open given you a warning if the switch is sticking or failed --remains in Estop with alarm
    Not being pedantic here but it's Normally closed switches not open.! Then if wire breaks you get warning, switch gets broke when it's triggered.
    The failure is usually caused by the switch never being used and then they stick down in the on position not the wire being broke ---------So when you release the machine off the switch it is stuck on the on position -so normally open would be a good idea ?
  1. Limit switch issues?!?
    By jonbabbz in forum General Electronics
    Last Post: 06-02-2014, 07:37 PM
  2. Another Home - Limit switch question
    By Cube3 in forum General Electronics
    Last Post: 26-12-2013, 07:51 PM
  3. FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
    By Shinobiwan in forum Items For Sale
    Last Post: 02-02-2013, 10:54 AM
  4. Limit switch Cable ...
    Last Post: 17-01-2011, 04:37 PM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
