Thread: Which Connection ?
Hi Jazz
Many thanks, the wires on my Stepper motors are long enough to reach the drivers in my cabinet, how do i sheild them if i do that?
Regards
Ray
30-09-2013 #2
Personally I'd use some shielded cable and shorten wires on motors and run this back to cabinet.
One thing I've done in past is have a small connection box near Stepper so unshielded wires to motor are short, I wrap these with foil and shrink wrap then use Gremflex shield on outer. Then run shielded wire from connection box back to control box.
Failing that then you could just wrap with aluminium foil to act has rough shield and then shrink wrap then cover with this Gremflex like seen here. CNC wiring Accessories Wouldn't be my first choice thou.!!
01-10-2013 #3
Hi Jazz
If i read you right you are suggesting i shorten the cables that are already attached to the motors, then run 4 core shielded cable back to the drivers, but will this not leave a small amount of cable unshielded ?
Ray
Connection the plasma cutter to the CNC machine?
By gr8fun in forum Plasma Table MachinesReplies: 1Last Post: 22-05-2014, 10:49 AM -
Or Guidance ;) Connection Name(s)
By Carlb1058 in forum Marketplace DiscussionReplies: 6Last Post: 13-07-2013, 12:48 AM -
Wire Connection Diagrams
By Lee Roberts in forum Stepper & Servo MotorsReplies: 14Last Post: 03-01-2013, 06:56 PM -
ghost in the x axis - bad electrical connection
By jonm in forum General ElectronicsReplies: 5Last Post: 11-04-2010, 08:31 PM -
plan request connection card PCPPS
By ali hedi in forum General ElectronicsReplies: 2Last Post: 07-04-2010, 08:18 PM
