Thread: Emco Compact 5 Conversion
Ron had the right idea by dumping the whole electronics and motors. I've converted a few small Lathes and usually the only thing worth keeping is the DC spindle Speed controller, which sounds like you don't have one.?
Motors are often underpowered and weedy so for sake £60 for 2 motors it's not worth the not doing if your keeping. If you want to spend some money and get great accuracy and repeatability with closed loop then buy the Leadshine hybrid closed loop stepper system, they come complete with Digital drives and are pretty much plug and play. . . More money but perfect for lathes.
Yes Mach will accept individual inputs for both Home and Limits for upto 6 Axis. Each axis can also share the same Input for Both Home and limit sensors so reducing the amount of inputs you'll need.!
01-10-2013 #2
Have you got any pictures of the control cabinet?
The Spindle motor looks like a DC motor, so it will most likely have it's own dedicated controller, and probably has some way of being automatically controlled.
Pacer compact rebuild
By GEOFFREY in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 26-12-2020, 08:27 PM -
CONVERSION: EMCO Compact 5 CNC Conversion
By sid8ball in forum Conversion Build LogsReplies: 1Last Post: 10-10-2019, 11:51 AM -
What may be the best way to convert my Denford compact router to mach 3?
By suesi34e in forum Denford RoutersReplies: 34Last Post: 28-03-2017, 08:24 AM -
CONVERSION: Emco Mentor Mill conversion
By Ross77 in forum Conversion Build LogsReplies: 63Last Post: 13-01-2016, 06:40 PM -
Emco conversion help needed
By Ecu-master in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 29-03-2014, 10:33 PM
