    Ok, thanks to all.
    I've now ordered a Toshiba VFD from Italy (as per silyavski's recommendation in this thread - http://www.mycncuk.com/forums/router...-remotely.html), here's the one I went for....
    INVERTER VETTORIALE TOSHIBA 0,75 kW 230 Volt MONOFASE USCITA MOTORE TRIFASE 1 HP | eBay (I'll never go larger than an 800W spindle, so this VFD ouight to fit my needs well)
    In the meantime, my thoughts turn to the spindle wiring - I've already got an 800W spindle but there was no information supplied, with it - I'm figuring it's likely that these water cooled spindle all have common wiring, so can anyone please tell me what the 4 pins are...
    I've seen reference on the net to 'U' 'V' & 'W' for the spindle pins...are these just arbitary abbreviations give to the three phases?
    Quote Originally Posted by HankMcSpank View Post
    Those are the correct abbreviations for each phase. The forth wire won't be connected to anything.
    Just wire to 3 connectors and if runs in reverse swap any 2 wires. . . Thats it.!!
    but I don't know which pins on my spindle are actually U V & W.....so was hoping someone could say by referencing from the keying prong? (assuming they are all standard?)
    It's arbitary. Just connect the 3 spindle power wires to U, V and W in any order and all that will happen if the order is 'wrong' is the spindle will spin the wrong way. If so, then as has been said, just swap any two of U, V & W.
    Cheers Jon saved me some typing. .
    It's occured to me that you might not be sure which are UVW and which is not connected (or earth)? If so then just use a multimeter, set it to measure resistance and check the resistances between all 4 pins - you should find that 3 of them (UVW) are virtually identical, and one is open circuit.
    I'm obviously having a bad (blonde?!) day.... that's my point, I have no idea which of the four pins on the spindle's connector socket are the actual spindle's power wires (that was the main thrust of the photo earlier ...if those sockets standardized, I'd hoped someone might enlighten me which 3 of the 4 are used)
    Option two is unscrew the connector and have a look. Whilst your at it you could solder on an earth cable.
    Sounds like option two it is! (I've used more energy asking on forum than getting a screwdriver out! lol)
    Re soldering an earth cable onto the spare pin ...is this towards connecting an earth to the spindle's casing?)
  1. Drawing of water cooled spindle
    By GTJim in forum Spindles & Drive Motors
    Last Post: 11-02-2014, 04:21 PM
  2. Replies: 17
    Last Post: 18-09-2013, 06:32 AM
  3. Chinese 2.2 water cooled spindle / Which VFD ?
    By dudz in forum Motor Drivers & Controllers
    Last Post: 16-08-2013, 02:22 PM
  4. water cooled spindle
    By alex wight in forum Generic Chinese Spindles
    Last Post: 21-09-2012, 09:57 PM
  5. water cooled spindle opinions
    By phill05 in forum Generic Chinese Spindles
    Last Post: 23-02-2012, 05:00 PM
