02-10-2013 #2
Cheers Jon saved me some typing. .
02-10-2013 #3
It's occured to me that you might not be sure which are UVW and which is not connected (or earth)? If so then just use a multimeter, set it to measure resistance and check the resistances between all 4 pins - you should find that 3 of them (UVW) are virtually identical, and one is open circuit.
02-10-2013 #4
I'm obviously having a bad (blonde?!) day.... that's my point, I have no idea which of the four pins on the spindle's connector socket are the actual spindle's power wires (that was the main thrust of the photo earlier ...if those sockets standardized, I'd hoped someone might enlighten me which 3 of the 4 are used)
02-10-2013 #5
02-10-2013 #6
02-10-2013 #7
02-10-2013 #8
Just wondering what the 'win is' by connecting an earth in the way you suggest?
The (aluminium) spindle mount conducts & the spindle chassis itself is conductive ....... the spindle mount is secured to the aluminium Z axis backplate...& I actually ground the backplate (for auto Z tool tip zeroing purposes)...therefore my spindle's casing is essentially grounded (albeit in a somewhat round about way!)Last edited by HankMcSpank; 02-10-2013 at 09:44 PM.
02-10-2013 #9
Drawing of water cooled spindle
By GTJim in forum Spindles & Drive MotorsReplies: 5Last Post: 11-02-2014, 04:21 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM -
Chinese 2.2 water cooled spindle / Which VFD ?
By dudz in forum Motor Drivers & ControllersReplies: 20Last Post: 16-08-2013, 02:22 PM -
By alex wight in forum Generic Chinese SpindlesReplies: 1Last Post: 21-09-2012, 09:57 PM -
water cooled spindle opinions
By phill05 in forum Generic Chinese SpindlesReplies: 7Last Post: 23-02-2012, 05:00 PM
