Hank my WC pump expired and I didn't notice, the machine cut 20mm Ali job for 2.5hrs and still spindle was only just a bit hotter than normal so I wouldn't worry about it for 30min jobs. . . . Put it this way If my pump wasn't switched on By VFD I wouldn't bother for short jobs.!
02-10-2013 #2
Thanks guys... I'm just trying to avoid the extra pipes, buckets, relays & wiring! It sounds like I should be able to get away with it for the type of usage my spindle will see.
02-10-2013 #3
That said for sake of 2 pipes & bucket it may be worth doing for long runs, better having the option to do it than not.
Regards Relays then Most VFD's have a in-built relay for switching external stuff so just use this. It also saves pump wear has it only comes on when spindles spinning.
Drawing of water cooled spindle
By GTJim in forum Spindles & Drive MotorsReplies: 5Last Post: 11-02-2014, 04:21 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM -
Chinese 2.2 water cooled spindle / Which VFD ?
By dudz in forum Motor Drivers & ControllersReplies: 20Last Post: 16-08-2013, 02:22 PM -
By alex wight in forum Generic Chinese SpindlesReplies: 1Last Post: 21-09-2012, 09:57 PM -
water cooled spindle opinions
By phill05 in forum Generic Chinese SpindlesReplies: 7Last Post: 23-02-2012, 05:00 PM
