Thread: Circular Pocket problem?
Got ballscrews fitted ?
Flats on circles are normally mechanical, slack in nuts etc.
You can compensate in mach under Backlash compensation but it's a cludge.
For one it doesn't work correctly and secondly if there is free play, even compensated for, the cutter can grab and pull the work.John S -
02-10-2013 #2
02-10-2013 #3
Check your software for overlap values or lead in lead out and also cutter comp activation points
02-10-2013 #4
Yup Jazz is right, that viagria isn't all it's cracked up to be.
Gave mine to me grandad, stops him rolling out of bed at nightJohn S -
03-10-2013 #5
Ah right! - To get good circles. You need to securely tighten the main casting to Y axis ball screw journal.
My "nuts" are now secure in a steel thong, but now have the problem of walking a bit odd!
Apologies to have wasted any ones time.
03-10-2013 #6
My father-in-law had Viagra to stop him pissing on his slippers.
conect software what do these 4 do, pocket, drilling and profile?
By windows20 in forum Machine Control SoftwareReplies: 5Last Post: 31-08-2016, 03:20 PM -
Feeds and speed guide/pocket book
By maritimesbob in forum Marketplace DiscussionReplies: 3Last Post: 10-11-2013, 09:38 AM -
Another screw problem
By Swarfing in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 09:24 PM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
