Thread: Multi thread cutting
03-10-2013 #6
Hi Rob
Gotcha now, i was looking into this the other weekend on one of the US CNC forums for a cheap ballscrew alternative. so all you need is 3 pieces of the bar threaded with 2mm pitch, diameter will have to be bigger than the smallest bearings you can get unless you were just going to put oilite bushes in the end plates, still relying on accuracy of the studrod but as it's rolled it should be near enough for making bits of plastic.
Mike
What do you think of this multi heads CNC router machine?
By mornrose in forum Manufacturer NewsReplies: 2Last Post: 08-08-2013, 02:08 AM -
Multi wire plugs
By Ricardoco in forum General ElectronicsReplies: 5Last Post: 26-11-2012, 01:47 PM -
Help coding M14 CCW thread using Welturn on CNC5 using small radius multi pitch tip
By Westy in forum Programmers CornerReplies: 0Last Post: 10-06-2012, 07:59 PM -
WANTED: 4 x 8 cnc router wanted and multi borer machine
By wyndham in forum Items WantedReplies: 4Last Post: 14-09-2011, 10:03 AM -
Multi stepping
By ptjw7uk in forum General DiscussionReplies: 8Last Post: 23-07-2009, 03:19 PM
