Thread: 3d AutoCad CNC machine parts.
so, here are some parts I've made, hopefully they'll be some use to you lot.
2.2kw spindle.dwg
bf12 ballscrew mount.dwg
bf12 ballscrew mount.dxf
bk12 ballscrew mount.dwg
bk12 ballscrew mount.dxf
nema 23 3.1nm.dwg
nema 23 3.1nm.dxf
sbr20 bearing block.dwg
sbr20 bearing block.dxf
sbr20 Rail.dwg
80mm Spindle Clamp.dxf
80mm Spindle Clamp.dwg
2.2kw spindle.dxf
15t HTD 5mm 15mm pulley.dwg
15t HTD 5mm 15mm pulley.dxf
16mm ball screw mount.dwg
16mm ball screw mount.dxf
16mm ballscrew.dwg
16mm ballscrew.dxf
30t HTD 5mm 15mm pulley.dwg
30t HTD 5mm 15mm pulley.dxf
sbr20 Rail.dxf
enjoy.
dwg's are in autocad 2014 and dxf's are in 2000.
THESE MODELS MAY HAVE DIFFERENT LAYERS. I ADVISE DELETING THE EMPTY LAYERS
the ball screws use a 25mm pitch but they have two flutes to make them look good.
the pulleys are based on a circular array, so while it has the correct amount of teeth, they're likely to be the wrong size.
The Following 2 Users Say Thank You to jcb121 For This Useful Post:
09-10-2014 #2
You should create a part library. thanks
Major issue with snapping to circles -Autocad 2013
By craigrobbo in forum AutoCADReplies: 8Last Post: 01-02-2014, 09:33 AM -
Concentric reducer in autocad
By Web Goblin in forum Computer SoftwareReplies: 1Last Post: 24-09-2012, 03:58 PM -
AutoCad 2007
By D-man in forum CAD & CAM SoftwareReplies: 15Last Post: 05-08-2012, 05:51 PM -
time to gather parts for new machine
By deannos in forum Gantry/Router Machines & BuildingReplies: 26Last Post: 21-01-2012, 02:23 PM -
Does anyone tell me the main parts of CNC Milling Machine?
By hoezap in forum General DiscussionReplies: 0Last Post: 07-11-2011, 01:25 AM
