    Thanks for the info - but I wish it was that easy. The lathe we have does not have the connections that the ones you have listed have. The lathe we have has no connectors on the display box at all. Inside on the crt the vga cable if plugged directly into the crt board (not with a standard vga connector). I have the tech spec diagrams but these do not corrolate with the actual plug P101B.
    Ok got in the back and found the VGA connector. - all sorted thanks
  1. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  2. CNC style lathe home brew Lathe for drilling and cutting.
    By Bodge in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-04-2012, 10:45 AM
  3. in calculating the tool path
    By Grumpy Mike in forum Programmers Corner
    Last Post: 31-07-2010, 10:18 AM
