    A used 4 axis CNC foam cutting machine. This is the cut 2300S model made by CNC Multitool, purchased brand new from Germany. Great for cutting styrofoam which can be used to make airplane wings, 3D letters, logos, columns, packaging, furniture, and similar. The machine is currently configured as a hot wire cutter, but this could be replaced with a horizontal rail to create a mill.
    http://www.cnc-multitool.com/cnc/foa.../cut2000s.html
    http://web.archive.org/web/20140816191611/http://www.cnc-multitool.com/shopseiten/cnc-multitool/download/catalogs/cut2000s_man_uk.pdf
    Dimensions:
    Maximum Cutting area: 305cm (L) x 105cm (W) x 130cm (H)
    Maximum Frame size: 312cm (L) x 180cm (W) x 166cm (H)
    What is included:
    • Frame and with two independent linear carriages that move in the x and y directions
    • One turntable with stepper motor, another turntable without motor
    • Driver board for stepper motor
    • Hot wire
    • Frame Assembly Manual
    All the steppers motors are fully functioning, however in both the x direction of both rails there is a limited range of motion. The y direction works finds and the carriages traverse the whole length without jamming.
    What you need to add to get a fully working machine:
    • A Windows XP computer with a parallel port
    • Software to operate the machine, e.g. MAch3 or Foamworks,
    • Software to generate the 4 axis g code, e.g. deskCNC
    • An electric unit to heat the hot wire
    • New or straightened central threaded roads (these maybe the possible cause of the rail jam, however buyer will have to diagnose the exact problem themselves)
    Asking price is £1000. Collection only from Oval, London, weekdays from 9.30am-6.30pm. The middle section of the frame can be removed such that the two rail sections collapse down to an area occupying:
    100cm(L) x 190cm(W) x 166cm (H)
    If you have a large enough van so the two halves of the machine can be transported together, that would be the easiest collection solution. Alternatively you are welcome to come and disassemble the frame itself into smaller components (within our working hours), though this could take a couple of hours.
ID:	15372   Click image for larger version.
ID:	15373   Click image for larger version.
ID:	15374   Click image for larger version.
ID:	15375   Click image for larger version.
ID:	15376   Click image for larger version.
ID:	15377   Click image for larger version.
ID:	15378   Click image for larger version.
ID:	15379   Click image for larger version.
    I have now sold this machine.
    Regards
  1. foam cnc carver- deep z axis - 4x4 bed
    By marbles in forum Hotwire Cutting Machines
    Last Post: 17-05-2016, 09:20 AM
  2. Replies: 0
  3. Not cutting perfect right angles and sticking on Y axis ?
    By Fivetide in forum Milling Machines, Builds & Conversions
    Last Post: 10-12-2012, 09:41 PM
  4. Z axis not cutting to required depth
    By dinasblu in forum Machine Discussion
    Last Post: 02-07-2012, 05:38 PM
  5. Where to buy long ball nose mill for foam cutting?
    By jamezwarner in forum Marketplace Discussion
    Last Post: 10-05-2012, 02:03 PM
