  1. #21
    Hello Jonathan, is there any power supply do you recommended? Jazz told me to buy this [URL="http://www.zappautomation.co.uk/en/digital-stepper-drivers/318-2m2280n.html"] but I have the same problem( I can only buy on aliexpress and ebay) maybe you can recommend another power supply so I can find it, I dont now if I need one or more than one. Thanks,you have been of great help.
  2. #22
    Quote Originally Posted by jpsicilia View Post
    Juan, I would have only told you to buy that PSU if you didn't want to build your own. My first choice and advice I'd usually give first is to build your own has it's cheaper and can be tailored to suit your exact needs.
    One of the problems with most Off the shelf PSU's is they all seem to fall short of the ideal requirements either on Volts or Amps so you end up buying 2 which makes it expensive and more room required in control box. So given your location then I would think it would be easier for you to locally source the parts to build one than trying to source ready built PSU to suit your needs.
  4. #23
    Thanks Jazz, I'll wait until buying the nema and drivers, and if you help me I think I can make the power supply. I have the tools, digital tester and welder to be able to do it. IŽll keep you posted. Thanks for everything!
  5. #24
    Hello guys I recieved all the goods from china for the cnc
    Axis X
    2pcs RM1610-1500mm Full length 10 pitch
    2pcs HGR15 -L1500mm
    2 AM882
    Axis Y
    1pcs RM1610-1200mm Full length 10 pitch
    2pcs HGR15 L1200mm
    1 AM882
    Axiz Z
    1pcs RM1605-350mm Full length 5 pitch
    2pcs HGR15 L=350mm
    1 DQ860MA
    Motors
    5PCS Nema 23 stepper motor 425oz-in,3A,2ph,1.8°
    Breakout board
    1pcs 6 axis cnc DB25/ interface board adapter milling engrave c10
    I want to thank you for your help, thanks to you I could select the components. I would like to know if you could give me some advice regarding the spindle selleccion. I have a 2050W router and do not know if I should use this or if it is better to buy a water cooled spindle or any other,since I donŽt know if the power that I need 2.2 kw or 3 kw is suitable for milling materials I will use.
    On the other hand, I want to ask JazzCNC for help to build the power supply appropriate for this equipment,and to help me decide on the components I should buy to make it. And finally I would like to know what I have to do with the components, what procedures I need to follow.
  6. #25
ID:	11439Click image for larger version.
ID:	11433Click image for larger version.
ID:	11435Click image for larger version.
  7. #26
    Hello guys I recieved all my stuffs from china,I want to build the psu suit for my needs. Can you give me an advice to buid it please.
    I have
    Axis X=2 AM882,Axis Y=1 AM882,Axiz Z=1 DQ860MA,four Axiz=1 DQ860MA,Motors 4PCS Nema 23 stepper motor 425oz-in,3A,2ph,1.8°. Thanks for everything!
  8. #27
    I have
    Contact me thru PM with your email address and I'll help you with PSU but won't do it over the forum as it can be miss understood by others and potentialy dangerous and damaging if done wrong or misunderstood.! . . . . . . Others may offer over the forum but I'm not prepared to do that.!
    Also At the moment looks like you plan to use AM882 for X & Y with DQ860 for Z & A but you have bit of a mixed up setup there mixing digital drives with Analog drives and if Slaving A axis with another(X) to form twin motor axis then you would be much better using same drives on each.! The AM882 would be best for this because they have stall detect and fault signal.
    Another thing is the motors.! Which motors are they and do you have a data sheet or model number.? Becasue you quote 425oz rather than Nm I suspect these are the high impedance motors often found cheap on ebay.? If so be aware you will get much lower performance from them for the same amount of Voltage compared to same power motors with lower impedance. This will affect the feeds you'll achieve and lower the amount of torque available higher up the speed curve.!
  9. #28
    Yes they are high inductance - the lower phase current (3A) is the giveaway.
  10. #29
    Then you're basically stuck if you want them for a reasonable price. Will CNC4YOU not ship to your country? If not, then you need to find 3Nm (425oz-in) motors with 3.2mH phase inductance. They generally have 4.2A current rating.
    It sounds like they're offering you a different brand of rail, e.g. LG or TBI, which is probably fine. Not many people here have bought them yet, so it's hard to compare the quality and even then the differences are likely to be so small it's hard to quantify. The TBI brand rails I got from aliexpress seem fine, so next time I need some I doubt I'll get Hiwin.
    Hello guys I try to follow your advice in all the buys. I bought this models, wt57sth115-4204a, Click image for larger version.
ID:	12414Click image for larger version.
ID:	12415Click image for larger version.
ID:	12416 and I find this on internet Click image for larger version.
ID:	12417Click image for larger version.
    I ask for low inductance as Jonathan told me. Ibought this in October 2013 and after 1 month of travel and the rest of the time in ARGENTINA CUSTOM y recived this. Some times I want to leave this country!! But my family is here.
    Thank guys I really apreciate your time.
  11. #30
    Great good to see you took Jons good advise. Those motors while still a little higher than some motors of same power are still have low enough impedance not to be restrictive.
    I got your PM and tomorrow will be intouch.
  12. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. Leadshine website and AM882
    Last Post: 24-08-2018, 01:59 AM
  2. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  3. AM882 works with Protune - but not with the ZPA5-INT BOB
    By badgerman in forum Motor Drivers & Controllers
    Last Post: 01-09-2013, 09:44 PM
  4. Problem with AM882 drivers !..... or it could just be me !
    By Buba b in forum Motor Drivers & Controllers
    Last Post: 03-04-2013, 09:28 AM
  5. AM882,s and Mach3 ......plus hair removal !!!
    Last Post: 26-10-2012, 05:11 PM
